Hello,
Apologies for the English - I have no German skills.
I'm a Canadian living in The Netherlands and am currently rebuilding a German 1992 PK50XL2 Automatic. This model was never sold here in Holland and there is very little information available. I need help with a running problem.
I have completely rebuilt the engine using new bearings, oil seals and piston. The engine originally had an oil injection system, I have removed this (too complex), and have switched to using premix fuel (easily available at service stations here in NL). I believe I have two problems. The engine has not been modifed.
Carburetor - the engine is difficult to start when cold (it has electric start only), requiring full choke and at least 15 - 30 seconds of starter. Once it is running, it is easy to start. I also find that twisting the throttle results in a slow response. It builds revs slowly compared to the 1986 PK50XL, that one is much more responsive to the throttle.
Variator / Clutch - when I rebuilt the engine it contained 7 weights 16mm x 13mm at 6 grams each. I have reduced this to 5.5 grams to improve acceleration. This has helped somewhat. I also wanted to modify the clutch but the springs appear to be unique to this model. The three friction shoes weigh 135 grams each so I have reduced these to 124 grams. This has improved the acceleration somewhat but it is not where I feel it should be. I don't want to do more modifications to the drive system as I feel the carburetoration needs attention.
When accelerating, it is very slow to take off from a stop. You almost need to put your foot down once or twice before it is stable. The belt drive doesn't move into 'high gear' until about 30kph. It will pull strongly from about 15 to 40kph and will reach between 50 and 55kph max. I don't push it too hard as the new piston/rings only have about 70 km on them. I have no idea if this is normal but compared to my XL (4 speed), or my 50S (4 speed), the XL2 is very sluggish.
Any assistance would be appreciated including any documentation on how to modify these engines. I don't want to increase the displacement due to the strick regulations here in NL but would like to improve the performance a reasonable amount.
I will thank you in advance for your words of wisdom.
Thank you and take care,
Peter Keun +31.61.583.1123
