CU
Let me know when there is a Vespa Competition in Macedonia.
Marco
CU
Marco
juno106: i think pkracer is right, the correct name of the service is COD (cash on delivery).
Ok, shipping within Germany is no so expensive. I thought you wanted to let rollerladen.com ship it to your country. The shipping costs from Rollerladen.com depend on the weight.The basic prices are for a package to a maximum weight of 10kg is only 5,95 EUR, from 10kg to 14kg is 6,80 EUR, from 14kg to 20kg is 7,95 EUR and any order with a weight to 30kg is 10,50 EUR. On all this prices you have to pay an additional charge of 7,50 EUR for surname deliverance by UPS. If you are buying for more than 300,- EUR, in this case the shipping is free.
I have an italian name, but I am actually German. But I love many Italian things, like Vespa (of course you could guess that one), Italian Wine and Food and the Italian mentality at least.
CU
marco
Yes you are right. Rollerladen.com is a good and reliable shop and you should have no problems by ordering your spare parts. But have a look at the delivery costs, so that you don't have unexpected additional costs. I have read on another shops website that the delivery costs are really low, just 9,- EUR for a 5kg package and if you buy for more than 250,- EUR the shipping is free.
If you need support in the restauration of your Vespa, don't hestitate to ask.
yours
marco
i was just curious. Nothing special. Nice to have an macedonian fan of Vespa.
yours
marco
@juno:
I just want to know. Where are you from??
best regards
marco
Ich hätte da noch nen Vorschlag für dich. Ein LED-Rücklicht das für eine gewisse Zeit nach dem Abstellen des Motors noch nachleuchtet.
Hab das Teil für mein Fahrrad gebastelt und muss gestehen das es super funktioniert. Stromquelle Gleich oder Wechselstrom ist egal.
Schau's dir mal an.
lg
Marco
das der Benzinschlauch über den Vergaser geht ist nicht gut. Der Sprit wird ja nicht gepumpt sondern "fällt" ja Richtung Vergaser. Wenn dann der Benzinschlauch dann über den Vergaser drübergeht, ist das nicht so besonders. Am besten den Benzinschlauch kürzen.
Wenn dein Vergaser schon von alleine abfällt, kann das kein Fachmann installiert haben. Muss bombenfest sitzen.
Mach mal Bilder von deinem Plättchenproblem
Gruß.
Hi Thale,
hab grade ein bisschen gesucht und das hier gefunden. Vielleicht hilfts dir ein bisschen.
Interessanter Teil: "Der Kondensator nimmt den Hauptteil des Öffnungsfunkens auf seine Flächen auf. "
Hi,
zuviel Watt beim Löten vielleicht? Gruß
Falls du deine Vespa auf 10 Zoll Reifen umrüsten möchtest und nicht weisst wohin mit den 9 Zoll Reifen kannst dich ja mal per PN melden.
Kurzer Film über die Vesbar in München und Vespa im allgemeinen.
Viel Spass.
erstmal Danke für die Infos.
Thale: Klasse Bild, Danke. Frage: Ist dir das noch nie passiert?? (mit dem Rausziehen des Hebels)
Die Hebel sind alle gerade und die Schraube ist fest angezogen. Sieht genauso aus wie auf Thales Bild.
Vielleicht werde ich mir mal nen neuen Hebel organisieren oder was basteln....
Wer noch Anregungen hat, nur her damit...
gruß
Liebe Gemeinde,
vielleicht liegt es ja an meiner Grobmotorik oder ich hab etwas vergessen zu verbauen....
Also: Wenn ich den Choke meiner Vespa ziehe kommt es manchmal vor das ich den ganzen Choke-Hebel mit rausziehe!! Eigentlich kein Problem, aber es nervt mich einfach wenn ich dann die Sitzbank hochklappen muß, das Werkzeugfach entferne und dann den Choke wieder schön einfädle....
Der Vergaser und die Maschine funktionieren einwandfrei, nur die Kleinigkeit stört mich noch ein bisschen..
Frage: Fehlt da etwas an dem Choke? Gehts euch genauso oder ist einfach nur mein Ori-Choke-Hebel schon so ausgenuddelt das er nicht mehr richtig hält.
Bilder kann ich grad nicht liefern, aber ich denke mal das ihr wisst was ich meine..
Schon mal Danke für eure Hilfe..
gruß
sorry wen ich dich enttäuschen muß aber das ist definitif keine 150GS sondern lediglich ne VBB wen überhaupt
und wen sie wie üblich den Asiatischen Restaurationsweg gegeangen ist das nur aussen hui und innen Schrott -->> vermutlich auch deshalb lässt sie der Besitzer nur ungerne fotos machen
rally221 ok dann halt ne VBB, hab mich trotzdem gefreut zwischen lauter Plastikbombern wieder mal ein bisschen Blech mit Vespa-Taille zu sehen. Gruß
ist er dabei?
@basti2507: Sorry ist auf dem Bild nicht dabei hatte längere Haare.... Gruß
Liebe Vespa-Freunde,
ich komme gerade frisch zurück aus meinem Thailand-Urlaub auf Ko Samui und wollte euch da von einem Fund berichten.
Beim Schlendern durch die Gassen, was sehe ich da? Ne alte 150GS....
Natürlich war für mich die Freude riesig , bei den ganzen Plastik-Rollern die da drüben sonst so rum gurken.
Allerdings muss ich zugeben dass ich die Bilder ein bisschen konspirativ gemacht habe, da wie eindeutig zu sehen ist der Besitzer nicht gewillt war Fotos seiner Maschine machen zu lassen (Auch nicht gegen einen kleinen Obulus!?? Versteh ich nicht!? )
Viel Spass beim Betrachten
lg
Hi und danke,
ne ist der Original-Deckel, der aber in Ultraschlechtem Zustand war. Zu meinem Ärgernis wurde er vom Spengler nicht passgenau ausgebeult und ging sofort an den Lackierer.
Die Feder der Fußbremse ist drin, aber manchmal bleibt sie ein bisschen unten. Keine Ahnung wo der Fehler liegt...... hab aber momentan nur noch fahren im Kopf und werde mich erst später wieder drum kümmern.
Viel Arbeit, viel Bier, viel Gefluche -> aber endlich fertig.
Hi,
ich glaube Guss lässt sich nicht schweissen, zumindest nicht mit hoher festigkeit.
Allerdings bin ich da auch kein Fachmann.
Korrigiert mich bitte wenn ich falsch liege
